davyg
is there anybody on here actually using prop savers with the rubber bands on their multi rotor vehicle??
have you had any problems with the bands snapping without warning?, and have you tried the ghetto method and used small zip ties instead of the rubber bands....
I am getting a tad fed up with trying to locate the appropriate prop adapter for my quad.... ordered 4 of the 3mm motor shaft collet adapters from HK, Hong Kong only to find that they are 4mm shaft fitting and that the collet won't fit over the bottom shoulder of the prop shaft.
still no closer to getting the bloody thing in the air...
