Bjarnek
I schools those who want to learn how to fly model airplanes and for this I use an old Multiplex Magister bought in 2005. Have not tested this model sens last year and due to that I probably will have some new students and would test model to check that everything works as it should .
After the test have I come to the conclusion that the servo with plastic pipes used for ailerons have become a bit too old and slow so I will replace this system with two servos mounted outside in the wing with direct rods instead. Fits poorly with a plane for buddyboxing if the control surfaces doesn't work properly.
Setup:
Model: Multiplex Magister
Transmitter: frsky Taranis 9XD Plus
Buddybox transmitter: HobbyKing HK6S 2.4Ghz FHSS 6Ch
Reciver: FrSky V8R7-II 2.4G 7CH
Battery: 5S 3300mAh Hyperion
Hope you like the video.
Do not forget to subscribe to my channel ......................
Setup:
