hey i like your signature. where is that quote, "a good landing..." from?
It's been a saying in aviation for a long time. Probably originated from some hangar chat between pilots.
Finished my Baron Saturday night, maidened it on Sunday. Flew 4 packs. In 10-15 mph wind. It is an awesome little plane. Probably 2 rolls/second, 180 degree turn in about 3 wingspans' width! After I pulled a couple of very tight loops, a fellow club member commented that cutting your own streamer doesn't count!
(My club is going to do some streamer combat, and the BB will be my "weapon". I have a feeling I will not enjoy fighting as much as just flying it around.)
Passworthy
*er I just noticed this is the baron not the brit page...* doh
I built mine, crashed it in some high winds with a hard nose in landing and then rebuilt it... got the re-maiden it today and it is an amazing flyer... high rates are zoom zoom and low rates are nice and smooth...
for my nose I killed it pretty bad... I ended up gluing together the walls and adding an outside doubler (tripler?) and some popcicle sticks to give it some strength... also added an extra layer up top after replacing the lower fold over and the original top.... all said she weighs in at 380g ready to fly minus lipo
i gotta ask about your spinner. i have printed 3 of them so far and all have died almost instantly upon spin up. the last one i printed in ABS, highest quality print the 3D printer could handle. it was beautiful and i thought for sure i had it whooped. it made it almost 1/2 way down the runway before catastrophic failure. what am i doing wrong?
thanks,
me
I'm a little late to the party and this is my first post. Just started flying 9 months ago with a foam Bixler -> Versa Wing (1) fail -> Versa Wing (2) :<) - Spitfire :</ and now the Bloody Baron. Maiden on the Baron was sketchy with 15% Expo but after a lawn dart from 50 feet, a new prop and 30% expo made it fly great. I've developed a relatively crash proof firewall - bbq skewers in all for corners of the fuselage running back full lengths - similar to nerdnic's but use them full length. I also double the firewall and put popsicle sticks across the fuselage top and bottom. Had the Versa Wing fuselage go in from 100 with no damage. My Baron setup is a RCTimer 2830 (http://rctimer.com/?product-120.html) with a 9X6 prop - 1500 turnigy 35-70 C and a whole bunch of downthrust on my custom fuselage. I call it the Dreamsicle - I'll put a skin on the second one. View attachment 148325 Flys awesome...Me likey!!!! I do have one minor problem in that it wags its tail sideways back and forth. I'm thinking my custom rudder may be a little small?
I'm dragging this old post back up. Bad weather and an extra C pack motor got me on this build. I haven't read all 22 pages of this thread, so maybe I've reinvented the wheel, but I made a few minor changes based on the issue some folks had with getting the battery inside the fuse, with proper balance.
Sponz, this looks like a great design, super simple.
This is the simplest, fastest and yet still very sturdy scratch build I've done. I can see how this would be a great combat plane, not a lot of time invested in building, replacement is quick and easy. I eliminated the power pod and just built the firewall inside the Baron. This opens up all sorts of space. I read that the battery needs to be all the way forward to balance, so I went 3 channel (no rudder) and tried to put as much weight forward as possible during the build. I added a shelf on the underside to sit the battery on (with velcro) after finding the balance point. I'll tweak the shelf and velcro after the maiden as needed.
Specs FT C pack motor (2218 1180kv), 9x6 prop, 1300 or maybe 2200 battery. The plane AUW (w/o battery) is 367 grams.
I look forward to the maiden. I just rebuilt my Scout again, so it's been WW I week.
View attachment 183140 View attachment 183141 View attachment 183138
Very clean looking build. Love the mods. Nice job! Good luck with the maiden.
Check out the SideWinder (link in signature) for the next generation combat plane in this series.
Thanks! Yeah, just looked at the plans. Yep, definitely next generation, more refined. Looks like you made the cg more central and finished the plane with a bottom cover, firewall and a battery box. Wing area and weight nearly identical. Looks to be as easy if not easier to build due to all the straight lines when cutting. Do they fly different?
