I got a late birthday present from my son last night - Raspberry Pi v3 and a web cam for an Octoprint controller.
Nice, beats the pack of cream eggs I got from my daughter this year
I wanted to like Octoprint but was really underwhelmed by it. If I used cura as my slicing engine I could see it simplifying things but since cura drives me crazy it just made things more complex for my workflow. Rep-server on the other hand I'm absolutely loving. Really need to recompile the kernel on my C.H.I.P. so I can get a webcam going soon still....
I was listener to the 3D Printing Today podcast yesterday and one of the hosts was talking about printing with flexible filament. The big problem he sees is how the filament often mis-feeds just below the hobbed bolt (or whatever you use). The first time you notice the problem is when the un-melted filament squirts out of the extruder via whatever path it can find. There are several designs that help by shortening the un-guided path. The host had just worked on one of these designs and added a clear acrylic panel to the side so you could see any feed problems when they first started. I thought it sounded pretty cool.
Yeah, that's why I'm not a fan of the extruder I printed. The trick seems to be keeping the filament constrained as much as possible from as close to the bolt/gear as possible. The geared extruder I printed has a channel for this but it's just not accurate enough. The extruder I'm using currently has the PTFE right up to the gear so it should do fairly well...but I'm not big on how long the PTFE is - could make retraction tricky with flexies...not as bad as with a bowden setup but same idea.
That's why I'm looking at a greg wade design that will let me run the PTFE right to the bolt like my current non-geared extruder only hopefully with a shorter path and the gears to help ease the strain on my extruder stepper. The setup e3d shows on their site is a greg wade cut open:
Just most of the designs don't have the 4mm passage for the PTFE and I think that may be a 3mm version because I don't see the coupler at the top of the cold end.
I will say filament changes with the e3d are way easier than with my old hotend. Before I had to heat things right printing temp before I could pull the filament out. Now even with the longer PTFE tube I can pull it at much lower temps because it doesn't stick in the heat break. I must have really messed up the PTFE liner in my original since the whole point of PTFE is to not be sticky
I have a very good Smoke and CO detector within a few feet of my Taz in the shop. It's part of my security alarm so I don't worry too much about fire. I do worry about messed up prints. 6 hours of extruded filament can may a big mess. I always make sure I can watch it for an hour or two (or through any tough to print areas) before I let it go unattended. If there are going to be problems with support or overhangs I usually see them early and restart with some adjustments. I'm learning to spend time studying the object and how it will be sliced before I begin. I really can't wait for the DWIM v1 Printer and Slicer package to be released!
PCH
Yeah, I've already printed all these parts so I know what to watch for
And they all have big footprints so adhere well which is nice since the only time I tend to get spaghetti anymore is if a print comes off the bed while printing - but that only happens on things with small footprints - and then usually only with ABS.
The 9+ hour roller_f went great last night. Finished just after I woke up
Three down one to go....then I get to redo the feet and corner blocks...and 3 more center pieces....
Only issue was I remembered why we had disabled the fire alarm in my daughters room...darn thing went off twice for no reason last night waking both me and her each time. Need to replace that one still. Her room is right next to ours, we all sleep with the doors open and the alarm in our room works fine so hers is mostly a backup...but I'll pick up a new one for her this weekend. Then again it may not have been the alarm...the new one over the printer went off twice yesterday evening for no reason. It could just be the crazy amount of dust/pollen in our air right now. I didn't know the pollen count could go over 10 :black_eyed: our allergies have been off the wall this spring. Killing me that we've got great cool evenings but are having to run the A/C just because there's too much junk in the air to sleep with the windows open
