Ok, it’s been a busy weekend so I’ll cover things one at a time.
The servos are mounted externally compared to the original size. I used yard flags for push rods and had no issues with anything here. Plenty of good throw and little flex in the rods.
The front part of the fuselage had no major issues either other than not using a power pod. You can install your firewall AFTER the bottom is completed. I wanted to be extra careful with my firewall to make sure it was squared up with the fuselage. I also added a couple layers of foam board behind the firewall for the protruding screws to go into. No need for battery punctures here folks.
I wanted to be sure that the landing gear wire was sufficiently sized as we had had this discussion as a group on what to do. I confirmed that the 1/8” wire is perfect here for the weight. I did not glue the gear in for this picture but I didn’t later either. It stays put.
I rushed through the wing mounting and aileron control setup to get out to the field. There was a window in the weather that I thought I should take advantage of. That being said, the maiden was as uneventful as Ben’s with the exception of me putting it through the paces and doing “all the dumb stuff.” It does not knife-edge well but it also would not stall. Ever. I had what I’d call “stupid” rates and it just didn’t care. Video to come but thought I should report.
