Repairs continued a bit last night. Sanded down the patches on the wing and they are ready for primer. I decided to move on and deal with primer once ALL repairs had been done.
Got the tailwheel replaced. The unit had sheered the metal in several spots and it was easier to just replace the whole unit. I did save the actuator and a few other parts for spares in the event I have another issue with it in the future. Also had to reattach the gear doors and tweak the gear door mechanism. It was much easier to work on this time... you know, with the gaping hole where the tail feathers are supposed to be :black_eyed:
Last thing I did was get her lined up and bolted back to the fuse. The mounts are firm and didn't give way in the crash. The plan is to get the nose lined up tonight and evaluate what foam can be re-used and what needs to be replaced. I'll then put a sheet of wax paper between the fuse sections and the wing, get everything aligned just right, and use GG to reattach, taping the seams from the outside so it expands inward. Then it will be glass repairs over the seams. I may add a little bit of carbon tow or heavy glass strips across the inside seam as well for extra strength.
