- Type
- Build Plan (PDF, AI, etc.)
This plane is a very easy build and will fly Super slow as is at 100%, however, I have found the more you scale it up the slower it will fly. My last build was at 160% and it was perfect. Also, anything over 115% you can use a standard swappable power pod from flitetest. The way I do it is to print out a power pod but not cut the tabs, finish the build with battery, then use the power pod to set CG. At 160% that is 5.25-5.5 inches back from the leading edge. Then when I have that I just cut the tabs and use skewers to hold it in. Makes balancing it a lot easier.
Here is a link to me messing around with it the other day.
Please post videos of your plane here so I can enjoy seeing them. thanks.
https://forum.flitetest.com/index.p...-slowest-plane-on-ft.58456/page-9#post-487743
