Hello, so today I had crashed my quad and I guess the battery got punctured cause I started to smell a sweetish epoxy like smell coming from it. So I then checked the cells for damage, and turns out the 4th cell was completely dead.
I then carried on to dissect the battery and desoldered and snipped out the dead cell. Everything seems to be functioning as anticipated, battery charger is detecting 3 cells and reading 3.9v each.
SO, considering that I had an 1800mAh 4s (14.8v), and took out 1 cell to make it a 3s (11.1v), would the mAh also go down with it?
I was thinking since its 1800mAh/4cells =450mAh per cell right? So 1800-450 = 1350 new mAh capacity?
Or does it only drop the voltage and leaves the mAh capacity in tact?
I know it is a pretty dumb question to ask, but if anyone has input, I'd greatly appreciate it thanks
