Interested in flying EDF's? Need to fly around slow? Will roll quickly and does a loop while moving out with some speed.! Want to learn about spooling up or down? How about a real super light model that will takeoff and land (2x's) without gear? Uses only ailerons and elevator?(Have another one that uses the "Udder Rudder for high alpha). How about takeoff from an incline table or vertical liftoff using stick I found? Best of all, EDF sits above fuselage so it doesn't ingest grass, dirt, pebbles and ruin those blades. By the way, mine is a cheap 5 bladed setup. Watch the slow takeoff from the table.
Model is made up of 6 pieces and after I got bored with it, adapted gear and prop and now it becomes my test bed for many ideas.
Seeing is believing. Then I will detail model and tricks used to get it to go. Then off you go to design F-86's,F-15's and then on to duals.
Notice antenna? Figure out the shape of model?
