Reprinted the center in MakerGeeks "Bomber Jacket Brown" PETG...which I'd probably just call Black but it has a very subtle reddish/brown tint to it if you print it thin and hold it up to a light.
Did the center in 60% infill and the arm pockets at 15% The center is still a bit more flexy than I'd like...but still the top/bottom plates are were it should get most of it's strength from.
It looks good. The latest tweaks to the design resulted in screw holes that M3 screws fit in perfectly and the arms don't poke out the bottom anymore.
The wires had just barely enough slack to re-assemble it without having to unsolder anything. If anyone builds one of these - leave yourself a bit of slack so you can replace arms/printed parts easily!
I still need new top/bottom plates before I can fly it. Just finished reassembling the MPCNC tonight but still have to mount the motors, wire the steppers and add the belts to it before I could start testing it and then I'll need to print a mount for my dremel before I could try using it to cut new plates. So will probably just cut some quick and dirty temporary ones on the bandsaw tomorrow.
Meeting up with someone to fly tomorrow afternoon so fingers crossed I can have it back in the air by then!
