Here's a simple trick for anybody using the Gold-n-Rod style pushrods. The most difficult part is normally getting the threaded rod into the pushrod far enough to be secure. The pushrod is fairly small and the farther you screw it in, the harder it gets.
What I do is wrap one end with a couple wraps of painter's tape to protect the threads, and then insert the taped end into my cordless drill.
Once in the drill, simply run the drill to screw the threaded rod right into the pushrod. It's super quick and easy!
And the end can then be installed and turned in/out as needed to adjust your final pushrod length.
Here's what I was aiming for with my pushrod locations - I wanted them to be as straight as possible for easy operation. In this case both pushrods ended up aiming pretty darn near exactly where I was aiming for. Final tweaking can be done by adding some slight bends to the threaded rod, although not ideal. In my case I'll have to do that as I miscalculated the servo arm locations and figured them sitting lower than they are, so I'll add a small Z-bend to both threaded rods to lift the clevis up a bit.
