Kurt,
I've had that problem with packs where the connectors aren't making good connections. For me, the fix is to unplug everything and plug it all back in again.
I've found this is more common with certain packs, usually bought in the same order. It doesn't exactly build my confidence in them, but I've also found my frequent troublemakers perform better if I gently press in on the connector end of the pack. It could be a weak connection on the balance lines inside the pack, but since I only use the middle pins for monitoring and charging, I haven't taken the trouble to rip into the pack to inspect.
