Best place to buy double sided foam tape.
Hello all!
I need some vibration dampening double stick foam tape to mount my KK boards to multi-rotors. So far I've just been using the 3M stuff you get at wal-mart, but the multiple layers I need to build up thickness is a little pricey.
Is there a good place to buy the stuff online? Doesn't have to be as strong as the 3M stuff, just good enough to hold a KK board on, and able to buy in more bulky quantities than the 3M wal mart stuff.
Thanks!
#2
My wife works at Harbor Freight Tools and that foam tape is sold there. Periodically, I'll get it on sale there, but I think the best is at Lowe's. I've found Scotch 1" x 14'7" roll of this at Lowe's for $13. I hope this helps.
Tritium
Amateur Extra Class K5TWM
#4
I use the 3M tape. I get 6 "Pads" to the inch which makes one of 3 mounting points (6 layers of foam) for my KK2 board. The mounting points are only half the tape width square or about 1/3" by 1/2" rectangle. 1 roll of the WalMart outdoor 3M tape mounts a LOT of boards.
Thurmond
