Bushwacker tips.
rcwees
i have a 1800 mah 3s and a power pack c motor. do you think this combo with the bushwacker could theoretically make a good plane. i saw the video and it looks like its a slow fly when it wants to be but can fly vertical at the same time. if this is the right setup for this what kind of prop should I use.
Pieliker96
Yep, your powertrain should be alright. A 10x4.7 would do well for STOL and good performance in the lower speed range.
Oldrover TJ
I've build a number of bushwackers. Almost all of them use that combo. You'll be a little tail heavy though.
Oldrover TJ
You're gonna need that battery all the way forward and try to be careful when building to keep the weight down. Or you can adjust the trim to keep the nose down. I generally fly mine pretty tail heavy. It certainly makes it a lot more "exciting"
Ligbaer
50 Percenter
or you could do a flugmoddel bushtrottel
but bushwacker seems more appropriate for power setup
