warpforge
Hi all. I'm working with my father on helping him return to a hobby that he has long shelved: RC airplanes. I've been trying to help him get into modern electric equipment, and I'm trying to work out the charging situation.
He has a Turbo Timber (the small one), and we bought the recommended batteries for it (EFLB2802S30). Because he's getting started, I read that a smart charger is the safe way to go. Since he'll probably want to move up to larger planes soon after getting back into the hobby, we went with the Spektrum RC S2100. This charger says it should handle basically any battery chemistry and 2S configurations (and of course much, much more).
Unfortunately, this battery and pack don't quite work together on their own. So, I looked into the connectors and found this E-flite adapter, which says that it should work to connect the battery to normal balance chargers.
I have three questions I'm hoping to get help on. I've scoured the Internet looking for answers, and I still feel like it's inconclusive.
I hope you're all having an enjoyable New Year in this hobby that works so well at social distance.
- In addition to the balance charging port on the charger, there's an IC3/EC3 port. The adapter has banana plugs. Do we need to connect these using an EC3/banana plug adapter like this? Or is the balance port sufficient for this relatively small battery? Is there a more appropriate adapter?
- When plugging the battery into the charger with the adapter and leaving the banana plug leads disconnected, the battery got very hot even though the charger was still unplugged. My father thinks the charger was running off some stored power, but I'm worried about a short.
- Given that these are two-cell batteries, do you have any advice on choosing a balance board that might allow charging multiple packs off of each channel on the charger? It seems like, electrically, it should be possible to charge up to three 2S packs off of one 6S connector and even have the charger balance everything.
