Cheap copy IMAX B6 Charger and 5200mah lipos
I have a few cheap copy imax b6 chargers and have been using the to charge my 3s lipos .
Normally i use them to charge my 1300mah or 2200mah 3s batteries and they do a great job.
But my question is am i asking to much of this charger to charge a 5200mah 3s ?
donalson
I’ll add I’ve dine 4 3s 2200s without an issue... I didn’t realize that I should/could be setting it to pump 8.8 amps safely assuming it could go that high...
I got a real one recently with the ac charger built in... I’ll have to see how it really compares at some point
#5
My copy knock off one came with an ac plug built in .
I've heard the copy ones are not properly calibrated .But you can bring up the hidden menu and do it yourself .
But i have been told you only get one shot at calibrating the balance voltages so you need to be careful .
I have not tried it myself though.
