Dr. Looping Looie
After FTFC18, I wanted to design my own WWII fantasy concept. It should be german and a jet because I have one 50mm EDF laying around. But I also wanted something special. At late WWII, Germany had almost no runways making the operation of conventional aircraft very difficult. Instead of making a VTOL that would be extreamely complicated, I decided to use natural existing runways like water. The plane could take-off and land on a river or lake or be operated ship based. Being a seaplane, it wouldnt need a carrier and could be launched from a destroyer or other ship. It should also have either retracts or a take-off dolly and landing skid for conventional ground take-off.
The EDF should be as hidden as possible in the back.
So I made some sketches of a single seater fighter:
On this pic, the side view is pretty final while air intaktes and horizontal stab of the top view will be remade:
I also made a model in Simple Planes, which is a simulator where you can build your own airplanes and it has shown the best water caracteristics yet.
Another thing are the air intaktes: they should be lokated over the trailing edge of the wing so they dont suck too much water in. I have two concepts:
1. NACA ducts: they are not too exposed and get the air very good in.
2. Normal intakes on the trailing edge: The Idea is to suck the air above the wing away creating a low pressure zone and more lift. Maybe this allows slow flying and short take-offs.
Do you have some more design suggestions?
Or name suggestions?
I hope to finish it in two weeks.
