BobK
Banned
I have been using 3M Super 77 spray glue with mixed results and was looking for an alternative that might work better and decided to try Elmers mulit-purpose, so far it looks good and I was wondering if anyone else has tried it and what their thoughts were. Super 77 works well, but it seems to have a discoloration, also if not used carefully it eats foam. The Elmers to me is drying clearer and doesn't seem to bother foam, and it has a lighter/dryer feeling to it.
Since I am using spray glue as an adhesive to try covering foam with plastic dollar store gift wrap I need something that sticks well, Super 77 works well for this, but I am trying to do an open structure with transparent film so cloudiness has been an issue. I plan to use gift wrap on balsa planes also so I really want to get rid of the cloudiness or at least most of it, Elmers seems to stay clearer. I have yet to try it to cover, so maybe then I will find an issue.
My ultimate goal would be to find a spray adhesive that I can use to make self-adhesive/heat activated covering (just like regular model airplane covering) at a fraction of the cost. I would like to unroll a full 8 foot roll of gift wrap..spray it and let dry..then roll it back up. Long-shot..maybe. I have tested and I do know I can let Super 77 dry (as far as it will dry anyway) and apply it with an iron on low heat, the glue does reactivate, but Super 77 does not dry enough ever to not stick if the wrap is rolled back up..I think Elmers will. Shrinking the plastic wrap works well after it is applied, nothing to worry about there.
Now, I bought a 4oz. can my local Wal-Mart fo $2.97 and had to double-check my receipt because on the website is shows $7.04..I can't explain that, it is the same can. Super 77 is running $10 for 7oz.
http://www.walmart.com/ip/Elmer-s-Multi-Purpose-Aerosol-Spray-Adhesive/19794380
http://www.walmart.com/ip/3M-3702-4262-3m-7-Oz-Super-77-Spray-Adhesive-77-SUP/20370819
My tests, Elmers on the left..77 on the right. I apologize for the horrible pictures, Santa didn't bring me a new camera this year. The picture of the foam is of bare foam, difficult to see but the 77 has ate and discolered it even with a light coat where the Elmers didn't seem to bother it at all. This is sprayed on clear plastic gift wrap, the blue background and yellow marks are my workbench showing through..not discoloration from the glues, but it shows the difference in clarity.
Here are a couple of pictures using gift wrap as covering with Super 77, it shows the foggy cloudiness I am trying to get away from. Granted, on solid colors or solid structures this would not be an issue at all.
I would like to hear any thoughts,suggestions, or experiences. I can't afford to try every glue on the market, but if someone has a better choice of adhesive I would like to hear about it.
