Ok, sorry took so long but got a sick kid so had to deal with that.
I entered the programming manually on my esc using the TX and throttle. I followed the directions I found online at the link xuzme sent me. it lists my particular ESC has 8 different options, brake, batt type, cutoff mode, cutoff threshold, motor timing, startup acc, motor rotation, default setting. so there should be 8 different options to adjust, but mine only beeps four times. (beep...beep beep....beep beep beep....beep beep beep beep....then repeats) Clearly not the same programming options than on the website and on the directions without having the correct and accurate program options I cannot program this esc. Correct?
