First FPV!! im so them happy!! (ended in crash, but its ok)
Here is my first FPV flight!! Tab, MEXICO
equipment used:
-goprohero2
-eagletree osd pro w/ guardian
-inmersionrc 5.8 trans
-fatshark dominator
-hk bixler(plane)
-1800 turnigy nano-tech
-turnigy 9x stock (mode 2)
-20 amps UBEC
the problem was that the "guardian" wasn't correctly attached plus semi-repair carbon rod that i broke a week earlier.
please enjoy!
#3
Nice,
Are you really using an 20 amps esc??? I used an 30 amps esc with the standard motor.
Really nice place to fly fpv, nice timed with the nice colored sun.
#5
Nice,
my mistake; indeed is a 30A w/BEC that i took from my stinger 64 from hk.
and thanks. probably i will try another flight today, but only after i finish the repair(change the carbon rod(broke), with an arrow that bought from walmart; and let me tell you that is the same size but the arrow is a lot stronger).
StoneKap
Executive Producer
Admin
I knew it turned out great by the title of your post... but I was still nervous for you. Great job!!!
#13
20120714_195328.jpg 20120714_195339.jpg 20120714_195350.jpg 20120714_195354.jpg
well, this is the repair i made; also i put the battery at the center for more space for batts/receiver/osd/etc.. and eliminate the balance-weight that come in the stock-bixler.
i left the balance port outside, so i could charge it easier(already order some extra-lead).
hopping to fly again this week :)
Burg
Never catch a multirotor
#15
Carlos, congratz with the FPV maiden !
Should be an easy repair I guess.
P.S. aren't you worried to loose that expensive pen in the field :cool:
Mark.
#17
Thats going to need some glue :0
no glue :) just the rod that it was already broken from another flight before this, i even use doubleside tape(scotch) for the union of the plane(its an ARF), becouse i saw the video in flite test about the glue, so i was afraid of some melting, but its strong like a horse. then i start using hot glue.... its like david said, "is the nectar of gods" :D
#18
Mark.
thanks Mark; and the hell i was!! you can bet that i almost need an extra underware when i lost video signal, the rain was comming i couldnt see it becouse the tall of the grass... i was jumping like a rabit in a greyhound racing.
