OK gang, I have almost everything I need to build my first Rotor Bones 370 quad.
Still waiting on a couple parts. Primarily the flashing cable for the KK2 board. Should be here this week.
Meanwhile, a question:
How do I drill perfect 90 degree holes in my wooden booms if I don't have a drill press?
In Chad's build vid he uses the guide to mark the holes, then whisks the boom over to a drill press. But I don't have one of those.
So...short of buying a drill press which I really don't need for anything other than this...any suggestions?
Assuming that they need to be 90 degrees exactly. If they are not, will the motors mount out of alignment, or will I miss the holes on the bottom plate? Neither sound good.
So looking for that perfect 90 degree hole drilling solution.
I'm sure I will have other questions along the way.
Thanks in advance, gang.
- Henry Joe
- Henry Joe
