JamesWhom
Project Air on YouTube
Hi fellas,
So I. In the process of building my first Tricopter, as you will have gathered by the tittle. I'm having a few problems and thought this forum post would be a good way to go about fixing them.
The Tricopter - Electrohub FT kit - KK2. 1.5 - FT power setup.
I used the flitetest build video to construct the Multirotor. I used David Windesål's tutorial on the KK2 board to program it.
1) The first issue is that the tail servo does not return to it's neutral position. It tilts either way but is not at the same angle when the stick reverts to neutral. Aargh! This won't do for yaw control! Maybe it's a Kk2 programming issue to do with the giros?
2) The second issue is that one of the motors (the front left) gitters and does not run as fast as the other motors. I partially fixed this by testing the motor unmounted to the frame to discover it ran fine. When attached back onto it, it just stutters and doesn't run properly, staying at a low speed whilst the other motors rev up. How can the frame be affecting this??
If you have knowlage of the Kk2 board, motor troubles on multi rotors, or anything that may help, please comment and help me!
Thanks - James.
Thanks - James.
