I don't think it really matters, as long as the props are counter rotating I don't think you'll be able to tell a difference.
Well - there's a different prop (a reverse prop) that goes on the clockwise motor. As long as you get that right, it might not matter. BUT, to be clear, the recommended orientation as directed when I built my p-38 with differential thrust: is as follows:
LOOKING FROM IN FRONT OF THE PLANE: the right prop (which is actually the left engine of the plane) turns clockwise and has a reverse prop
the left prop (which is actually the right engine of the plane) turns CCW and has a standard prop
Check out the build video for the flitetest P-38 starting at 2 hours and 51 minutes into the video.
However, wikipedia notes the opposite (keep track of orientation from behind or from in front when reading) so I remain a bit confused tho my p38 flies great set up per the flitetest video. Wikepedia:
And from Wikipedia:
Counter-rotating propellers, also referred to as
CRP, are propellers which spin in opposite directions to each other.
[1] They are used on some twin- and multi-
engine propeller-driven aircraft.
The propellers on most conventional twin-engined aircraft spin clockwise (as viewed from behind the engine). Counter-rotating propellers generally spin clockwise on the left engine and counter-clockwise on the right. The advantage of such designs is that counter-rotating propellers balance the effects of
torque and
P-factor, meaning that such aircraft do not have a
critical engine in the case of engine failure.
Drawbacks of counter-rotating propellers come from the fact that, in order to reverse sense of rotation of one propeller, either the engines must be adapted to turn in opposite directions or one propeller must have an additional reversing gearbox.
