Foamboard Tri Copter with EDF Vectored Thrust
VAALLEON
Not built for accuracy but lots of fun… Some wobbles and jitters but gets the job done perfectly.
Ch5 high: pitch and roll differential thrust, yaw thrust vectoring
Ch5 mid: pitch, roll and yaw thrust vectoring, minimal tilt. MonoPhan thrust vectoring algorithm.
Ch5 low: pitch, roll and yaw thrust vectoring, optical flow position hold and BARO. No tilt… Arduino supported.
Fully foamboard with carbon fiber and aluminum enforcements.
Thanks!
https://www.youtube.com/watch?v=vxFPAqHvpYU
Boberticus
wait, so..
is it just set up as a tricopter with extra servo outputs, and then the servos are slaved on the TX, and then the different slaves are set to a single switch, all on the TX?
or does it command the flight controller to enter a different flight profile, and you've just pre-programmed this in to the flight controller.?
what software are you using?
this is pretty darn cool, and seems like a pretty neat thing to try with a normal tricopter too.
