Ft might mini arrow battery
Chiran
I'm going to build a mighty mini arrow can anyone recommend a battery to it i have 1500mah 3s battery 2s 1200mah battery and 3s 850 mah battery what is your suggestion
HVB79
Yes a 2204 2300kv motor is fine and can be used with the same props. The 22 is the dynamiter of the motor in millimeters and the 04 is the height of the motor stator in millimeters. The stator is the part the wires are wrapped around. So a 2204 motor is the same dynamiter and one millimeter shorter than a 2205. In general the larger the motor the more power it can use. However one millimeter is a small difference.
See this article & related video for a more information:
https://www.flitetest.com/articles/beginner-series-power-system
