MEGAjig
Hi Guys,
I just wanted to share my latest build. It is a modified version of the Versa Wing. It is slightly bigger with a straight body section in the middle. I increased the cord length in the middle and also increased the spar height in the middle slightly to have more room to fit a battery inside. For this particular model I will just install a power pod in the front as a tractor. I will post more pics as the build moves forward.
This version will allow for a much larger prop in the back as a pusher as well. Also I will mount the servos vertically sticking out of the top of the wing on each side as I find it easier to get access to the control horn.
I have attached the plans I made. They need some tweaking while building but overall not too bad.
View attachment FT Versa Bold 1.pdf
View attachment FT Versa Bold 2.pdf
