Here are my Aura5 Flapperon config notes.
First I followed Josh’s video:
Note: I have a Spektrum DX6 programmable xmtr. On the DX6 assign a 3 position switch to Ch6/Aux1 (I use switch D as it is just above the throttle) then go into Digital Switch Setup, select your switch (I used D) and set the values for each position as follows: 0=-51%, 1=50%, 2=100%. These values do two things, they tell theAura5 what position the switch is in and the value drives the flap throw. So -51% = Aura Switch Pos. 2 and is flaps UP, 50% is Aura Switch Pos.1 and about 1/3 flaps down, 100% is Aura Switch Pos.0 about 2/3 flap down. Now go to your PC and open Aura config tool, connect to your Aura5 and power it on too so you can capture live data (this makes adjustments a breeze). For Mix 1, select Mix Switch Channel as Ch6/Aux1 and set Switch Type to 3 Pos. Switch. Make Mix 1 Active in positions 0, 1and 2. I set Mix Rate Negative at -125% and Mix Rate Positive at 75%. For other Mixes, make the Aura Switch Pos. 2 inactive. Remember to write to Aura each time you make a change and then check that change with xmtr control.
Have fun
