Getting Control rods in the netherlands.
Anand
Where do you guys get your control rods?
I'm having a hard time getting control rods, mainly the longer ones, i have used bicycle spokes but they are too heavy, shifter cables for the simple soarer, the train/model shop here in Utrecht only has 15cm rods of spring steel.
razor02097
Rogue Drone Pilot
#3
You could look for mig welding wire. Just make sure it isn't flux core (that stuff is brittle) get the stuff you would put in a welding machine that uses welding gas.
Anand
#4
I have a roll of mig welding wire but its 0.6mm and too thin also its harder to make straight, i'm building a wire straightener: https://www.youtube.com/watch?v=aZDxoi0N5g0
for shorter rod i have used BBQ skewers with shrinkwrap and wire, but for the longer ones on the bigger models its harder, since my current options make the plane tail heavy.
Anand
#7
Some models need longer rods, i have build some models like the bloody wonder with the short ones and had to move the servos back and that added some CG problems. The store i have found now has the same rods but 100cm long.
Balu
Admin
I see.
I'd have asked the hobby shop owner if he has longer rods though :). I'd not be surprised if he cuts them to that length.
Anand
#9
No they are pre packed also they are 0,8mm the wire u have now is 1,2mm, its a train store, if you say that its for air planes they kick you out.
Tritium
Amateur Extra Class K5TWM
#11
Not MIG Wire. Use TIG welding filler wire. it is straight and should be found in 1 meter length's and many diameters plus it is available in practically any metal alloy you could ever want from steel to titanium.
Thurmond
