Gremlin Guardian props set screws
dansteeby
Hi all,
The props that came with my Gremlin Guardian kits are a very loose fit on the shafts of the motors. There are 2 "set screw" holes on either side of the center hole on the prop, and the kit comes with screws for securing them, but the screws are too small for the holes: they drop right into the hole and doing so for both the set screw holes doesn't tighten up the prop. Turning the quad upside down after doing this results in the screws falling out of the prop, and the prop falling off the motor shaft.
I think I have some 2.5M screws from other projects on hand, but they seem too large in diameter for these holes. What screws should I get for these props?
dansteeby
I got it sorted thanks to FT Support: I completely didn't understand that the screws go through the props and screwed into the motors themselves. Lesson learned!
