PHerder
Probably will not be many updates as I am working several builds at this time (2 ARFs of larger, much larger, L-19/O-1e, one is 47" wingspan, the other 98.4").
You might be able to see the bushed motor mounted and the RX/ESC/servo platform sitting next to the left wing. I am still figuring out the best way to mount it. The electronics came out of Nieuport 17 micro that disassembled itself on a gym hardwood floor.
I have modified the rear controls to be functional since this plane was originally designed for rubber band free flight. I don't know how they expected to wind up the rubber band and have the structure not collapse... I just handle it and have to rebuild the pieces that break...
This the second balsa plane I have tried to build after a 45 year layoff... If this works, I have a Guillows Cessna 150 that is actually designed for RC (and FF and CL) that I will build.
I have Doculam (1.5mm) to cover it. I used it before on my micro Piper L-4 Grasshopper build.
