mrstamp80
Has anyone tried swapping the flight control board?
Basically taking the FC from the nano qx and putting it in the nano qx FPV??
Ok, Here is my thought and reasoning why to do this. My flight time with the Fpv nano qx is about 1:45 - 1:50 seconds before low voltage warning comes on and cuts me out of the air. Before anyone jumps to conclusions here is a list of things i have done to the quad to try to get more air time.
1 - 10 different batteries , same result
2 - New props, as the slightest nick will drastically cut down on flight time
3 - Talked with horizon and they have sent me 2 different boards (no charge) the last time i talked with them was told about 2 min is all you should get.
4 - Took the camera assy out of the FPV Nano qx and the flight time is the same
So after I fly my fpv nano qx and the low voltage comes on, I can take that same battery out and right away put it in the regular Nano qx and fly it for another 3 solid minutes before the low voltage comes on. With that said there is very little weight difference between them. 0.5 oz nano qx 0.7 oz fpv qx take the camera assy out of the fpv qx and you got 0.5 oz Now keep in mind i did this test with my own postal scale and no battery in it at the time.
My question is does anyone think that if i swapped the boards i should get a longer flight time? Does anyone know if the low voltage warning is set to a different voltage between the boards? I haven't tried this but was wondering if anyone has.
