Hello
I am having trouble getting the GPS to work with this board. Every time I try to connect from the multiwii configuration software it cannot read the com port. However it connects fine without the GPS plugged into the ic2 board.
The red light on the ic2 board is pulsing 3x, indicating a GPS lock. Any ideas?
My Setup:
- MINI MWC Flight Control Board and DSM2 Receiver ACC/GYRO/BARO/MAG
https://www.hobbyking.com/hobbyking...Receiver_ACC_GYRO_BARO_MAG_US_Warehouse_.html
Parameters changed from default:
#define AIRPLANE
#define I2C_SPEED 100000L
#define HK_MultiWii_SE_V2
GPS:
#define GPS_BAUD 115200
#define UBLOX
#define I2C_GPS
- IC2-GPS Nav Module
http://www.amazon.com/Hobbypower-I2c-gps-Module-Receiver-Multiwii/dp/B00H77BQ7U
Flashed using I2C_GPS_NAV-v2.1rc2 downloaded from google.
#define GPS_SERIAL_SPEED 115200
#define UBLOX
-Crius Neo-6 GPS
Configured using txt file from ic2-gps download (u-blox-config.ublox.txt).
Thank you for any help!
-Frank
My Setup:
#define AIRPLANE
GPS:
#define UBLOX
#define I2C_GPS
#define UBLOX
-Crius Neo-6 GPS
-Frank
