cdfigueredo
Hello everyone, my knowledge is very basic, but I think that with your help I will be able to solve it.
The point is that I want to improve my Foam cutting tool. As there are no commercial transformers here, I have this old Soviet transformer from a Krim 218 TV. I also have an old Russian projector that has a transformer with a 6V output that I use to heat a shorter resistance of about 30 cm. The 12V transformer I use in a cutting arc of about 70 cm with a fine nicrom wire or guitar string indistinctly (no apparent differences). The problem is that the bow wire is heated just enough to cut, but it feels like not enough power.
Here in Cuba everyone claims to use it that way, but to me it doesn't give me maybe all the result I expected because the cut is extremely slow. Maybe it's a mistake in the way the cables are connected.
This is the TV transformer that I feed with 110V and according to the person who sold it to me, it gives an output of 12V with ??? A.
Input left side, output right side
110V Input
input details
12 V output
output details
My questions:
I see that the transformer has several tabs on both the input and output, so...
Are the connections made correctly, in such a way that it gives me the maximum amperage for 12V....???
Could I also get another 6V output for this transformer to avoid using the additional transformer for the shorter hot cutter tool?
Or better still, to have a "potentiometer" able to regulate the output of the transformer in a variable way of 3 - 6 - 12 V, etc... ??
Forgive my ignorance and thank you in advance.
110V Input
input details
12 V output
output details
My questions:
