Hi--I am new here and seeking some help.
Froncy
I have a twin engine Bronco that shows a flying weight of 4.4. lbs. without fuel or engines. It calls for .15 engines but I have two .25 engines --question is do you think that will be alright to use versus the .15's??
... I have two .25 engines --question is do you think that will be alright to use?...
It somewhat depends on your flying skill. , It might be a bit fast for a beginner. It will be fine for someone with good flying experience.
PsyBorg
Wake up! Time to fly!
.15 sounded small to me so I did a quick look for a general thrust of a .15 motor. I saw that a .15 is about 804g (1.77 lbs) thrust with an 8.4 prop. By those numbers I think that would be a struggle getting a 4.4lb plane off the ground. But this is not my expertise. Need actual thrust tests of your motors vs the wing loading and all that stuff that requires maths to understand.
I am sure others can point you at actual numbers you need to know for sure.
Froncy
Thanks for the info- I think I can fly it- not real good but not a beginner and I thought the .15 seemed a bit small plus I only have 1 .15 but 2 .25’s I will try to post before and after flight pics.....landed plane or rubble lol
The .25 's will work fine but it will be lots faster with the recommended engine sized props. You could Expo the throttle to 80%
Bricks
Or just throttle back, times it can be a life errr plane saver having extra power. Me personally hate flying an under powered plane.
Aviator936
id say that actually it doesn't matter what your engine type is unless your worried about the weight or flight time of your aircraft. just remember if its sensitive decrease the throttle and stay calm!!!
Froncy
Thanks to all-some great ideas. I actually found another .15 so I am going to go that route-- I will let ya'll know how it works out.
