Hi, I'm Han
hancafe
I have been watching flite test for little over a year now and I just decided to join the forum because just recently, i have started making my own planes out of cardboard and cutting them out. My problem is, is since I am 13, I don't have any money and I was really hoping to get into the hobby. If anyone has a controller that still works but they don't use it anymore, please contact me because I was looking at a DXE and if I have to, I will be purchasing that. Just wanted to say hello.
Hancoffee
FDS
You don’t need a Spektrum transmitter to get flying, a Flysky FSi6 x with receiver can be had for $60. Does more than a DXE and will do any FT plane fine. It also has a screen and allows you to change settings without an app, unlike the DXE. Second hand transmitters are a good solution too. You don’t need to rush out and buy a TX, take time in making a choice, it’s your main link to your plane, so if you buy a bad one it will make flying harder.
Also you can build planes with no radio gear, either chuck gliders (Check out Nerdnic RC’s chuck gliders) or you can set up all your servos with a $6 servo tester then build the whole thing right up to being ready to fly without adding the receiver. The Tiny Trainer can even be built as a chuck glider, 2ch RC glider, powered 3ch or full 4ch, all in the same plane.
Chuck gliders will teach you plenty of the skills needed to build FT type designs, plus they are usually only one or two sheets of dollar tree FB, making them cheap. You can make an elastic tow line launcher to get them higher in the sky too.
A lot of people use this cheap Wiltoys RTF to get flying, it’s small, light and easy to fly.
basslord1124
Welcome to the forum Han!
Yeah there are other cheaper options for radios. You don't have to go with Spektrum. @FDS gave a lot of good awesome starting tips. Something I do wanna mention is the WLToys plane he linked also has an average flight time of 20 minutes so that'll give you plenty of time to learn to fly. And I've heard those planes are pretty indestructible too. I think going the chuck glider route is great that way you can work on your building skills and then use that time to save up money for electronics.
