DutchRC
Hi there people
I received this HobbyEagle A3 SuperII flight stabilizer a few days ago.. Personally I don't use stabilizers a lot in planes, so this is mostly to show You how to install / configure it.. And offcourse test how well it performs
Here is a link to this system: HobbyEagle A3 SuperII Stabeliser
In this first part I will offcourse show you what it looks like, and what comes with it.. More importantly though: I'll talk you through the setup & installation procedure of it:
Decription:
SpecificationsBrand: Hobbyeagle
Item:A3 Super 2.0 II Flight Control Stabilizer
Main Controller: 32-bit MCU
Sensor: 3-axis gyroscope and 3-axis accelerometer
Gyroscope Scale Range: ±2000 dps
Accelerometer Scale Range: ±4g
Input Signal: Standard PPM with center point 1520uS, or S.Bus serial data
Output Signal: PWM max frequency 333Hz, 1520±500uS
Input Voltage: 4.8V - 7.4V
Operating Temp: -10 ℃ to 50 ℃
Weight: 10g (excluding wires)
Features
Works with all major receiver brands including Spektrum, Futaba, Hitec, JR, Tactic, and more.
Integrated design of 6-axis (3 gyro+3 accelerometers ) 32-bit MEMS sensor for self-stability and self-balance.
Advanced brown-out fast recovery ability provides better security and reliability.
6 flight modes: Normal Stabilization, 3D Attitude Locking, Auto-balance, Auto-Hover, User Defined, and Gyro Deactivated Modes.
2 stick control modes: Manual Mode(MM) and Auto Mode(RR/AR).
Various wing types: 1AIL+1ELE, 2AIL+1ELE, 1AIL+2ELE, 2AIL+2ELE, delta-wing and V-tail.
Independent gyro gain adjustment and gyro ratio selection for each flight mode.
Separate adjustments for servo travel limits.
Up to 333Hz servo operating frequency, compatible with all analog and digital servos.
5-level response rate setting allows you to use it on gas-powered planes.
Compatible with HV (7.4V) receivers and servos.
Flat or upright mounting orientations.
Newly designed config GUI makes gyro setup simple and intuitive.
Decription:
Features
