I have two 1000mah 11.1 v lipos that came with a kit from Lazertoyz for my Old Speedster project. I also bought the Imax B6 charger. I'm using an old 450 watt PSU from an old PC to supply 12v to the alligator plugs, and the charger is working. When I try to charge either one of these new batteries in any lipo charging mode I get a low cell battery error and it stops charging. When I select to monitor the cells it shows identical voltage for the top row of cells, and then 2.00v on the second line as if it were reading a fourth cell that isn't there. I think this is causing the program to post the error. It is doing it with both batteries. I have read the booklet, and watched every four button charger tutorial on Youtube. I am setting up the charge rate at 1.0A for a 1000 mah and checking the voltage is set to 11.1v (3S). What is causing this error? What is the 2.00v reading on the second line? Do I just have a bad charger?
