- as written, i use a picture zoomed to the actual size on my home computer screen i wanna build it in, and take the measures i can get then, - the foamboard thickness (eg. 70mm height, will get 60mm with 5mm fomboard skin) and looks on other pictures s to determ the style, if cant find a picture in actual angle, its not so difficult make something pretty close.... as i wrote in another post here.
To get the skins size, well if starts in one end, its not too difficult individually get them to fit by trail & error. Or, can use plain writingpaper fitted on outside and light behind, to se where the formers are, and mark how rhe panel need to be. This plane even have a "angled line" going all the way... pretty nice to use for where top & bottom parts are connected
Absolutely awesome! And with Canadian insignias I like even better!begins get more and more complete. Servos is lacking, and retracts (in mail) spinners are raedy, just not installed yet .
View attachment 206424 View attachment 206425 View attachment 206426
Thanks! Designed by a Canadian company, so get Canadina insigniasAbsolutely awesome! And with Canadian insignias I like even better!
Your builds are getting ridiculous. I had to look twice at the photos because I didn't believe that was foamboard. Amazing work!begins get more and more complete. Servos is lacking, and retracts (in mail) spinners are raedy, just not installed yet .
Thanks! one of reasons you know.... show what can be done of foamboardYour builds are getting ridiculous. I had to look twice at the photos because I didn't believe that was foamboard. Amazing work!
3D printed:
2 different pilots. Both adjusted on helmet, hand angle eg.
4 mid size rockets, 4 small rockets, 2 rocket launchers
I tried print some spinners... but they got to be close to "crap" on how fit with the spinner base, and ditched. Used Dynam Grand Cruiser ones instead.
Retract servoless holders.
Canopy frame was made in pvc-foamboard, to easier get strength for the canopyshape. Canopy glassing is from a national sodawater brand plastic bottle.
Holders on side of canopy for 2 rockets are also in pvc foamboard. easy to shape by heat, and it keeps shape, even if flexes in need.
Plane is to be setup with differential thrust, and rudder. Then its not needed for servoassisted steering of front wheel, the taxing goes good without, as long the frontwheel have a trailing style. (wheel center in back of the vertical rod)
I build, quite medicined, and sort it out if is ok, or need rework , when gets more "clear moments"That is the way to go. Save weight and the hassles of setting up a servo. As always nice work. I hope U recover well. With what I have, flying is totally out of the question and I have enough energy to build for 2 hours a day. though today, I think I might do 3. The not flying is what is killing me.
