When it comes to laser cutting the foam board, is there a special setting on the laser cutter, and is there a risk of toxic emission?Six sheets of laser cut foamboard, coming right up!
This all led to quite a stack of foam. After a couple days I finally got my act together and started working in the fuselage. Each fuselage side is three pieces: two outer panels taped together for the full length, plus a side doubler. The top and bottom are the same way, and so you essentially attach the top and bottom and front and rear halves.
The elevator is made in one piece, with a fold over bottom layer for extra stiffness. After all, the elevator on this plane is almost as big as the wing on the Speed Deamon.
As per standard hotliner practice, the servo goes up under the elevator so a short, strong pushrod can extend through the open back into the elevator control horn. I used a Towerpro metal gear servo. Probably a bit minimalist of a choice, but the control loads are typically pretty light.
And so here it is all decked up with the servo enclosed. A pretty long extension is required, even with the receiver well behind the wing mount area. Quite a bit bigger than the Speed Deamon!
Caleb wanted a closer look:
Hope thinks I'm nuts. It's one big airplane!
With that done, I installed the aft top deck and glued on the 1/8" ply firewall which is then secured with fiberglass strapping tape in a crisscross pattern, then sealed up with packing tape for good measure. I also used a covering iron to seal up the fuselage seams in the nose before attaching the firewall so that I could fair everything in smoothly and reinforce all the seams with packing tape.
Just found this thread now and wanted to mention that yes foam board is toxic when it burns. I believe it creates styrene gas which is toxic to the nervous system. However if you have proper filtration and exhaust it can be done safely.When it comes to laser cutting the foam board, is there a special setting on the laser cutter, and is there a risk of toxic emission?
What about ironing fb edges - is that an issue? It doesn’t seem like it would be since it’s such a small amount...Just found this thread now and wanted to mention that yes foam board is toxic when it burns. I believe it creates styrene gas which is toxic to the nervous system. However if you have proper filtration and exhaust it can be done safely.
Um Im pretty sure it only releases a gaseous state at temperatures higher than what you need to iron at but the small amount isnt that bad anyway.What about ironing fb edges - is that an issue? It doesn’t seem like it would be since it’s such a small amount...
That's insane! I'm looking to do a 4s hotliner - what prop do you recommend? For my rimfire .15 size motor I'm thinking a 9 inch with a decent pitch will be the best option, but I can't find any good props from APC. I also don't want to spend $135 on a prop...The scaled down 50" version hit 139 mph on 6s with a GM 17x26 prop and NTM5060-380. Eventually I'll try that setup on 8s.![]()
That's insane! I'm looking to do a 4s hotliner - what prop do you recommend? For my rimfire .15 size motor I'm thinking a 9 inch with a decent pitch will be the best option, but I can't find any good props from APC. I also don't want to spend $135 on a prop...I did however see the APC 11x13 - what if I trimmed that down to 9 inches long - would that be a good idea?
