So I'm a RC flying noob and I placed orders with Flite Test and HobbyKing to set myself up to build a couple FT planes and a FT Tricopter for Christmas. I chose the NTM 28-26 1200kv motors for both planes and the Tri and ordered the long shaft version at the link below. I also order the NTM accessory pack which includes the bolt on prop adapter.
https://www.hobbyking.com/hobbyking...Series_28_26A_1200kv_286w_USA_Warehouse_.html
When I got the motor I realized that the extra part of the shaft is coming out the bottom end of the motor and that it wouldn't be going through the prop adapter.
Did I goof and pick the wrong shaft length? I realize that it should still work fine with the extra shaft hanging out of the bottom. But do I need to be concerned that the shaft may get bent easier in this configuration? I also checked the HK site and it doesn't look like they sell the short shaft as a replacement part for the NTM series.
