L Edge
Circular is a offshoot between my delta and geobat plane eliminating any vertical stabs to keep the weight down. Object is to see how many different shapes I can get that fly with the EZ Pack. Results from this one are impressive using the EZ Pack.
Concept:
Exploring weird designs requires some sort of stability so the first thing I did was give a 14 degree dihedral to the circle. Next, made the wing segments of the "Circular" level in X and Y planes with the tail up righted to 14 degrees to make this a one piece plane. Plane requires 1 cut(1/2 circle out) and 3 scores to assemble. After designing 5 planes, began to realize different foam boards makers play(weight vrs CG) an important part why some will not fly properly. Suggest everyone use Adams Readi-Board to eliminate errors. I am doing both.
Build:
1) With scraps, build 2 dihedral guides 14 degree so that each section is slightly less than 3 inches from centerline.
2) Take 4 scraps and glue together. This is for the levelness of the wings. If you glue right, will need no shims.
Steps on paper:: I am old school, by paper, if pilots like, maybe someone can produce computer plans.
1) Draw 12 1/4" circle.
2) Draw 9" circle same radius.
3) Draw vertical centerline of 12.25 circle.
4)Draw 2 lines 3" parallel to centerline inside large circle.
5) Draw 2 lines 1.5" parallel to centerline (prop shaft) that ends at 2.5" down on vertical centerline. That is where your carve out motor mount that is pushed in to foam.
6) Prop slot is 9/16 wide by 2 3/8 long centered about prop shaft.
7) Cut out lower half circle of 9" circle.
8) Transfer to foam material.
Enough for today.
Concept:
Build:
Enough for today.
