A bit of an old thread but you certainly can use AEO EDFs.
They are not as powerful as many but they are quite efficient at converting the power they do use into thrust so this means you have to build light, very light, to achieve good results. With the smaller units you have to take light to the extreme but if you do the results can be impressive.
A 40 mm AEO in a 32" (800 mm) span DH Venom.
All made of 2mm Depron (when if was available!) so even with a 1400 mAh 2s on board it weighs just 202g.
It doesn't fly particularly fast so an easy hand launch. Fully aerobatic It also flies nicely at part throttle, taking about 7 amps, so a 12 minute duration is possible. Not many EDFs can match that.
In the same vein
two 40mm AEOs in a Depron DH Sea Vixen of the same span.
More power a bit heavier so a bit faster but still hand launched.
You don't have to go for maximum power with an EDF just minimum weight and those AEO units are particularly light.
