Hey everyone. While this is my first time ever posting on the forum, it is by far not my first time using the FT forum to get in the air. I am not entirely sure what I would do without the generosity of the individuals that take their time to respond to others in the community with less experience. With that said, I apologize in advance if this is not the proper, “protocol” in which to post something like this. Nevertheless, I am truly out of options and hope that someone out there may be able to help me with my current build!
It all began with a WLtoysF949 the Cessna 187. I learned to fly on it, and felt this odd attachment to it whenever the brushed tri motor gave out. So I opted to do a little research to see what a brushless upgrade would look like. That decision in and of itself is the catalyst that set the rest of my(limited) experience in motion. I went online and ordered a plethora of parts online from various different outlets. 1.7G, 1.9G, 2.5G and 4.6G servos, 1806 motors, 2212 motors, and accidentally five 1103-8000KV motors. Pushrods, ESC”s etc. I basically wanted my own parts warehouse. All and all I spent less than $150.
I scratch built the FT mini Scout, with 1.7G servos, Turnigy Plush 20A esc, and 1806 motor and I love it. Straight forward on the electronics and all is well. Then I had bought an old Flyzone Aircore Folkwulfe for a steal when I originally conceived the notion of getting into the hobby..so I put a turnigy 18A in there, with the 2111 I think? with 1.7G servos as opposed to finding a “power cord” and all went well with that build. . I built 2 more scouts with the various electronics I had laying around. But I did not want to fly them until Inhad the Cessna in the air. The Cessna was what I would get back into the swing of things with so I wouldn’t destroy my new scout or the 190 since I’d be a little rusty coming off of the manufacturing period lay-off if flying....which brings me to the issue...
Not only did I want the Cessna in the air, I wanted simulator projects. Small, 1S powered 500mah type airplanes running on the 1103 motor. The information online is scarce, however a few different threads pointed to this being the absolute best motor for a micro >60G plane. The Cessna weighs somewhere around 50G. The popular setup is an 1103Brushless running off of an S-Bus inverter with a micro quad ESC running off of the original Wltoys PCB. However, like others, I could not get the setup to work for me. Apparently the key is to have a Flysky radio and to be able to set the throttle points. (Wltoys runs off same protocol as flysky...so I got a flysky transmitter to fly it. Whenever I could not get the PCB to send the signal to the motor I opted to use a receiver I had at the house. 4Ch ultra micro FLysky receiver. It weighs absolutely nothing.
I hooked the servos, and the ESC to the new receiver and voila!! Everything works....I put a GMS 2x3 on, and went to the field. It didn’t end well...after calibrating the ESC the 1103 motor seemed to take forever to spool up to full speed...I went back home and calibrated and programmed some more and got it to finally seem to work. However now, it only runs at constant speed! Soon as I move the throttle stick it goes to a set RPM, and then doesn’t accelerate or decelerate. It remains at a constant no matter what. I continued to try and program it and now it will not work at all. It’s a 7A brushless(XP). Anyhow, I decide to try it on one of my turnigy ESC”s and it will not even turn the motor unless I hook up one of my 2S batteries to it. When I do this, I get full throttle curve, response, etc. but the 1S does not so much as power the receiver board with the exception of the light. This seems to me as if the ESC is somehow not working for a lack of a better term with the 1S battery..I’ve tried multiple 1S 500mah batteries and multiple receivers, and it’s the same result. I’ve changed the 1103”s out for different brands, and it’s alwYs the same result.
Based on what others had said(20 min flight time with this setup) I felt this was just some hidden gem of a motor with a magical weight to thrust setup for micro builds. I had dreams of micro bipes and ultra micro foamies and all sorts of stuff based on the #”s in some of the 1103 threads...but I cannot seem to find the benefit of this setup if it will not run off of the 1S..I know that this is a ton of information with a poor delivery of what exactly I am asking. However I hope thst amongst the info I’ve provided that someone out there may have some ideas about the 1S 500mah setup on the 1103 or if someone else has an idea of a better motor/ESC/prop combo for what I am talking about with the micro builds...I personally was led to Believe that 1103-8000KV on a 500mah 1S would be wayyy overkill for >60G airplanes...however I cannot seem to even be able to produce enough thrust to make the plane so much as wiggle on the table...I have to leave the prop on, otherwise the motor will not spin..I guess this is a fail safe of sorts for the ESC..but anyways...I truly got into this with the aspiration of using these 1103”s for similar size scratch builds while being able to use cheap, 1S lipos...the brushed version can fly 20-25 mins...on the Cessna...and I had a blast flying in wind, Soaring at the coast, etc. and wanted something close to the same power just brushless...but unless I am missing something, it seems to me that I have messed something up, or the other pilots claiming these things are leaving something out in their posts....
Any help, thoughts, would be greatly appreciated!
