Can a mighty mini arrow be flown with out power and if so how should it be balanced. Thanks keith
So-cal hunter New member Oct 16, 2024 #1 Can a mighty mini arrow be flown with out power and if so how should it be balanced. Thanks keith
skymaster Elite member Oct 16, 2024 #2 You Mean like make it into a glider? Last edited: Jan 31, 2025
Jo's squadron Elite member Oct 16, 2024 #4 yes the mini arrow is really good at gliding. I would move the CG two inches back.
H HVB79 Active member Oct 17, 2024 #5 The CG should be in the same place if the model is powered or not. I would put the CG where the plans suggest for the powered version. You can also build it without the center pod as you don't need to mount a motor.
Mr Man Mr SPEED! Jan 6, 2025 #6 nippeagles said: Where would the CG go without needing to mount the motor? Click to expand... About 1cm farther back I believe.
