Foamforce
I’ve built a mini scout with an 1806 2280kv motor, a 12a ESC, and 6x4 prop. I’m planning to run a 2s battery. From what I gather online, this setup should use about 10a.
I have a little 350mah 25c battery. So I take 25x.35=8.75a right? So this battery can’t supply the full 10a, only 8.75a, right? So if I run this at WOT, will it ruin the battery first, or will it cause a failure in the ESC or motor somehow? For additional fun, the load wires on this battery look very thin, maybe 20ga. So maybe those would melt first? Will I have a flaming meteor plane?
So then the sanity question, if I were to run a 450mah battery on this plane, to calculate the discharge rate needed, would I take 12a / .45 = 26.66? Should I add 25% overhead to that as well, so maybe I should be looking for at least a 33C battery?
Thanks!
Thanks!
