Modified Long EZ
arman4
Had some modification ideas with this build. Shortened the nose, modified canards, reinforced center frame with foam and wooden skewer just behind the center of gravity, added two more winglets in the rear of the fuselage reinforced with skewers. Oh and the most drastic change was converting from pusher. 1806 mounted on the shortened nose. I used an 1806 2400 KV motor, 6 Channel Lemon receiver non stabilized receiver, 20 Amp ESC, and two 9 gram servos.
arman4
Oh 254 gm with 800 mah 3S battery. This is an experiment as the FT Long EZ used 5 gram servos and was a 2S setup I believe.
