jross
A shout out to @Hai-Lee for encouraging me to do this build when I mentioned I’d destroyed a lot of wings trying to fly one without success. I have an F Power Pack I’ve been struggling to find a plane for and it’s perfect for this job.
This is one of the simplest builds I’ve ever seen and very elegant at the same time. Said to be near indestructible if built well. Seems like a perfect wing for me to learn on. I'm going to learn to fly a wing if it kills me as it has all of my wings thus far. @Hai-Lee has a build thread in our forums I’ll be following. Everything is explained clearly so I feel confident it will go well. I’m a big believer in the KISS principle. This plane is all that.
@Hai-Lee Build Thread
https://forum.flitetest.com/index.php?threads/collaborators-build-1-800-mm-kfm-flying-wing.54085/
I started with printing a tiled version of the plans. To fit a sheet of foam board, I reduced the size to 92% of original which was 31.5 inches. My plane will be 29 inches. Took 3 sheets with some good sized leftovers to build parts for other planes. I’m using white glue to assemble the layers and glueing all 3 layers at once. I don’t want to be rushed getting things right. Nice to have some wiggle room to align complex shapes and be able to coat the entire surface with a thin layer of glue. I found the paper on the foam sucked up glue and I had to spread the glue around to make sure there was some remaining on the entire surface. I didn't spare the glue. It's cheap and easy to clean up.
Parts cut out and ready for glueing.
Parts glued and ready for weight. Scrap strips added behind top layer to distribute weight over the middle layer allowing me to glue it all in one step. Used scotch tape to keep things from moving around.
"Wife's out of town." Had to empty a shelf in the pantry before I removed it to use as a press. Figured I'd use some of the items I removed to weigh things down. Gotta remember to put the pantry back together before she gets home.
Waiting for glue to dry. It'll be back on the bench tomorrow night.
Time to cook a frozen pizza.
