EliteFunk
FunkMaster
Ok so I installed the frsky DHT DIY module in my T9X, and the D4R-II RX in my blackout. opened cleanflight turned on ppm, went to receiver tab and set all midpoints end points etc. set up all my switches, everything looks totally fine. However when I power it up and try to arm it nothing happens. If I try different flight modes with other switches the leds change indicating it works but it wont arm. I tried putting arm on different switches and also tried arming with sticks instead. nothing works. the RX is getting a signal cause everything shows up correctly in baseflight and the leds change when I activate horizon mode but I cant get it to arm. Failsafe is set and everything should be working, I'm completely stumped, please help.
Thanks
Thanks
