Need help to calculate engine size and servo size
HilldaFlyer
I am just sitting here smiling :)
What a project! It is way beyond my ability to help, but I had to comment to let you know that I am completely amazed! Great Build.
When I design planes, I follow the following guidelines when selecting my power setup:
10watts=~1oz. of thrust
So you'll need around 160watts per pound, or 32000watts total to give your 200-pound Spitfire a 1-to-1 power-to-weight ratio.
Since watts=amps*volts, that would mean running a 12S LiPo (about 40 volts) on a power setup that pulls 800 amps.
So you'll definitely want to go with gas. (I have no experience with gas, sorry).
GREAT BUILD!!! This is awesome!
ZoomNBoom
Its not like you need anywhere near 1:1 power ratio to fly. ~25W/lb will get you in the air, three times that is plenty for non 3D flying. So that works out to roughly 5-15KW. You can do that electrically, but its not going to be cheap:
http://www.espritmodel.com/hacker-a2008-motor.aspx
Around $1000 for the emotor, $500 for the ESC and the battery is not going to be free either.
For scale flying, this is probably plenty though:
http://www.hobbyking.com/hobbyking/...Max_100cc_Size_Brushless_Outrunner_Motor.html
and almost affordable.
This project is insane btw! I still have a hard time believing this happened by accident, but way to go!
kevparang
Man that is beast!! Yes, you do need to register and maybe even need a permit?? Possibly, I do not know the specs, but if you could tell us more about that plane, it would be nice.
PsyBorg
Wake up! Time to fly!
"B" "I" double "Guh" BIG pretty much sums up the spec's for this thing. I am really surprised this was not already in its own FT episode just for the build.
