quorneng
Andt.T.
My concern is that the motor should not get hot with a 9x6 on a 3s, particularly if it is in the open stuck on the front of a plane.
The fact that it did and is now not as free running means something is wrong with it, possibly a magnet has come loose or a crash bent the motor shaft.
The size of a 3s battery or the ESC will not cause a motor to run hot. You are using a 9x6 'e' prop not a 9x6 prop for IC engines? IC props are less efficient so require more power from the motor.
I fear that motor is now scrap.
As an aside the weight of a plane always matters.
Its weight determines its flying speed and thus the power required to fly and also the speed it 'contacts' the ground! The kinetic energy of an impact is proportional to mass and its velocity squared so extra speed makes a big difference in any impact.
Eventually too much weight makes a plane virtually unflyable.
Is a 3300 mAh 3s the recommended size?
